Forums >> Revit Systems >> Technical Support >> Selected Linked dwg Topo in Revit 2012
Sat, Sep 10, 2011 at 2:27:52 AM | Selecting Linked dwg Topo in Revit 2012
hazzyhill
Hey guys!
I linked a 3d surveyed topo dwg drawing to revit with the following properties & steps:
1. Unchecked current view only, unit MM, placed at 1st storey.
2. Scale up to 1000.
Now here comes the problems. After I scaled up the imported symbol. I can no longer select the file by just clicking on it nor I can acquire coordinates/ generate toposurface from the imported dwg.
The same method used to work in Revit 2011 but apparently not Revit 2012. Any idea what went wrong? Help would be greatly appreciated.
Regards,
Chin
Edited on: Sat, Sep 10, 2011 at 2:28:21 AM
Edited on: Sat, Sep 10, 2011 at 2:28:58 AM
Sat, Sep 10, 2011 at 6:23:24 AM | Selected Linked dwg Topo in Revit 2012
4 Stars: 205 Votes
I did the same you did and i don't have any problem like that, I can select, I can generate toposurface..... no problem.
Try that in a new project.
Mon, Sep 12, 2011 at 8:32:20 AM | Selected Linked dwg Topo in Revit 2012
hazzyhill
I have tried it so many times using different templates/units/3d topo dwg. It still won't work. The problem only occur after I scale it up 1000 times. From then on i can no longer select the import symbol by just clicking on it. I can only drag a box to select the imported symbol and use the move command (MV) to relocate the linked dwg.
I used Revit 2011 following the same steps and using the same files; and it works perfectly. Any idea what could possibly be the problem?
CREATING A TOPO FROM A CIVIL CAD FILE
Fri, Sep 29, 2017 at 3:22:33 PM
Revit 2012 Export dwg of imported categories
Wed, Oct 1, 2014 at 8:00:17 AM
Revit MEP 2012 View Port Error with Linked views
Tue, Sep 4, 2012 at 11:50:45 AM
Topo elevation reports different value than actual location on z-axis in model
Wed, Sep 26, 2018 at 11:47:41 AM
dwg elevated points can't create topo in Revit
Fri, Nov 8, 2013 at 1:04:35 PM
Page generation time: 1.4307
