Forums >> Revit Building >> Technical Support >> ARROWHEAD GRIPS???
Fri, Aug 26, 2011 at 9:57:03 AM | ARROWHEAD GRIPS???
treshernandez
Well, I changed the linework of a planting tag to match our standards and now the only arrowhead grip I have to work with is the break in leader line. What happened to the grip at the tip of the arrow and how do I get it back?
Thanks,
Tres
Fri, Aug 26, 2011 at 10:09:41 AM | ARROWHEAD GRIPS???
If you place a tag with an attached end setting, there is no grip on the end....it is attached to usually the center of the family.  Change the tag to free end and you will have a grip .... but it will no longer move with the element.
PS - I deleted your previous post which was the same.  Remember - we asked you to bump posts rather than creating a new thread.
Edited on: Fri, Aug 26, 2011 at 10:12:22 AM
Fri, Aug 26, 2011 at 10:21:09 AM | ARROWHEAD GRIPS???
treshernandez
Cool, thanks. But, I'm not quite sure how to bump a post. I tried reposting it through thread options, but I'm obviously overlooking this. Sorry, man.
Fri, Aug 26, 2011 at 10:49:07 AM | ARROWHEAD GRIPS???
TKennedy
4 Stars: 8 Votes
The simplest and fastest way to bump a post is to just reply to it. That will move it up to the top of the list.
Fri, Aug 26, 2011 at 1:41:06 PM | ARROWHEAD GRIPS???
treshernandez
Easy enough. Thanks, guys.
elevation arrowhead don't show up at print
Tue, Nov 14, 2006 at 1:26:57 PM
Possible to Developing or Edit an Arrowhead?
Thu, Mar 11, 2010 at 4:11:57 PM
Room Tag Leader Arrowhead Problem
Thu, Jan 21, 2016 at 11:18:11 AM
Custom leader arrowhead
Tue, Jan 27, 2009 at 1:34:05 PM
How can I add a new type of arrowhead
Mon, Dec 16, 2013 at 2:13:01 PM
Page generation time: 1.3849
