20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Revit Architecture
1 Posts No Rating |
Am in the right place?? couldn't find a link for a forum for revit architecture 2012??
need some assistance here.... trying to model a parapet wall flashing/capping using the sweep function. having trouble loading family into revit. also... why are you unable to model in place in section view???
There is no seperate forum for the different Revit issue dates.
Are you doing a profile?
Did you assign the profile to the correct use in the profile family?
I don't remember if I tried to model in place from a section view so I didn't know you can't. Ooops - just checked and I can.....you must have a different issue.
You are trying to model a sweep, this requires that you first provide a path for the sweep. Generally this is done in the plan or sometimes elevation view. The first leg of the path at it's center will be the location of the model in place section detail, if your section is looking anywhere else but at this point you will not see it. Then you model your flashing what ever, and assign a material to it and finish the sweep.
Autocad Architecture join the Revit Architecture Suite |
Tue, Aug 19, 2008 at 9:14:55 AM
YOUR OPINION ON REVIT ARCHITECTURE 2014 VERY URGENT |
Tue, Apr 30, 2013 at 11:09:29 PM
Is there anything Revit Architecture can do that MEP can't? |
Fri, Apr 17, 2009 at 5:10:43 PM
Just received New Revit Architecture Bundle |
Mon, Sep 22, 2008 at 6:26:19 PM
Vicozzio - New Revit Architecture User |
Wed, Sep 3, 2008 at 5:00:52 AM
