20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Exporting Revit files
160 Posts No Rating |
I have emailed a Revit file to myself on my google email address so that I could use it elsewhere on my laptop but I cannot open it on my laptop from there again. All I did was attach it to the email from the location where I save it on my workstation project file location. The file is about 4 or so mb.
Is there some sort of export file or procedure I have to go through to do this.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net |
PS I am using Revit 2011 on both machines.
Cheers Dermot
www.dmbd.net |
You don't say if this is a work shared file or not. If it is, you will have to open it detached.
Is your laptop configured to run Revit? Did you save the file seperately from your email?
"You don't say if this is a work shared file or not. If it is, you will have to open it detached.
Is your laptop configured to run Revit? Did you save the file seperately from your email?"
Sorry I do not know what a work shared file is?? I am running Revit 2011 on both machines. I saved the file to a folder on my laptop then tried to open it from the new location!
Cheers Dermot
www.dmbd.net |
Exporting issues... exported dwg files missing information |
Thu, Jan 24, 2008 at 11:43:21 AM
exporting pdfs |
Tue, Dec 5, 2006 at 1:59:54 PM
Exporting a Revit project (contains linked files) to dwg - coming in as Blocks |
Mon, Mar 21, 2011 at 3:03:58 PM
Exporting Linked Revit Files coming in as Blocks |
Fri, Sep 2, 2011 at 10:16:38 AM
Exporting revit to DWG files |
Fri, Nov 10, 2006 at 4:29:06 AM
