29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Visibility of elements within a family
148 Posts No Rating |
Greetings. (RAC 2011)
I have created a simple floor-based generic family to represent a sunshade support. This support will be a tapered Structural T that extends out from the wall +/- 1200mm. This 'support' will be connected to the concrete columns of the building structure, where one is present, or it will have its own tube steel column, where the building structure is not present - so I have a visibilty parameter for the column
I am having 2 issues:
- When the column is NOT visible, none of the symbolic lines appear in plan. But they do appear when the column is visible.
- I am unable to JOIN the support to the wall, once it is inserted.
I would appreciate any suggestions ...
Ian Shafer
Principal Consultant
True North S&F Consultants |
Can I turn off visibility for elements under the toposurface? |
Mon, Jan 14, 2008 at 1:09:34 PM
visibility of structural elements |
Wed, Dec 1, 2004 at 11:25:49 PM
Family element Visibility Settings |
Tue, Jun 11, 2013 at 4:08:30 AM
Visibility elements in a room tag |
Mon, Aug 9, 2010 at 2:58:33 PM
Visibility Problem - please help!!! |
Fri, Jan 11, 2008 at 10:20:02 AM
