78 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Levels missing from Section?
Fri, Aug 5, 2011 at 9:56:52 AM | Levels missing from Section?
archie456
3 Stars: 1 Votes
Hi,
I have an issue with levels not showing up in sections.
We have created a 7 storey large building; the building has several ‘Building Sections’ where all level markers show up OK.
There are also several wall sections, but on two of these level bottom three level markers and dashed line doesn’t show at all, but, for some reason the top two levels are fine.
I’ve checked to see if they are hidden etc but all seems OK.
Any thoughts on what this could be?
Fri, Aug 5, 2011 at 10:41:15 AM | Levels missing from Section?
In order for the level to show in a section ( column lines too), the datum must cross the clipping plane of the view.  Either they are rigt / left ... in which case just uncrop the view and drag them over, or if they may be beyond the view, find a perpindicular view and drag them over.
Fri, Aug 5, 2011 at 10:53:49 AM | Levels missing from Section?
archie456
3 Stars: 1 Votes
Finding a perpendicular view worked - Thanks.
Is there any way of 'resetting' the plan datums to cover the whole building extents - or at least viewing the plan extents so that I can check them?
Fri, Aug 5, 2011 at 11:34:23 AM | Levels missing from Section?
Yes, you can set datums to scope boxes.  You can read about those in your HELP
Section Tags missing (again)
Wed, Aug 26, 2009 at 10:50:38 AM
Levels are missing - I tried all solutions on forums no result
Wed, Jan 30, 2013 at 10:57:43 AM
Levels missing Revit 2012 [ 1 2 ]
Mon, Sep 28, 2015 at 3:29:41 PM
19
Section callout missing
Mon, Dec 16, 2013 at 4:00:09 PM
Levels in Wall Section
Mon, Jan 26, 2009 at 6:39:01 PM
Page generation time: 0.4051
