78 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Three part Section cuts
Tue, Aug 2, 2011 at 7:32:36 AM | Three part Section cuts
DandFInc
I am currenlty working on a project with an architect within the same company and we are sharing a central file.  When I place a section cut on my structural framing plans the "cut from" part of the bubble keeps placing A-002 instead of S-200 which is the sheet it is being cut on.  I am new to REVIT and any input would be great.  Thanks
Tue, Aug 2, 2011 at 7:41:14 AM | Three part Section cuts
The plan you are using is an independent - not dependent plan - correct?
Tue, Aug 2, 2011 at 7:54:03 AM | Three part Section cuts
DandFInc
I started my framing plan by duplicating the floor plan that the arch created.  If I show properties for my framing plan it says independent for dependency (although it is greyed out as if it can't be changed).  I am using Revit structure 2010 fyi.  Thanks.
Section Cuts
Mon, Nov 10, 2008 at 9:21:07 AM
Section cuts WAAY too deep!
Tue, Jun 7, 2011 at 5:34:55 AM
Rouge sections cuts
Wed, May 2, 2012 at 4:07:32 PM
Multiple Section Cuts as duplicates
Thu, Dec 4, 2008 at 11:44:59 AM
Detail Cuts
Wed, May 3, 2006 at 5:03:48 PM
Page generation time: 0.3810
