Forums >> Revit Building >> Technical Support >> Sections not showing due to off the Right Angle
Fri, Jul 15, 2011 at 7:56:33 AM | Sections not showing due to off the Right Angle
cboersen
I added building sections to my floor plan and they do not show on the elevations or other building sections.  I figured out that they do not show because they are not a right angles to the elevations, to the other sections or to each other.  The reason they are off the right angles is because the building is oddly shaped and angled.  Is there any way to force a section mark to show when they do not automatically show do to being off the right angle plain?
Fri, Jul 15, 2011 at 10:06:27 AM | Sections not showing due to off the Right Angle
TKennedy
4 Stars: 8 Votes
If you really have no way to make the sections at right angles to your elevation view, the only thing I can think of is to create a new section in the elevation view and use the reference other section option.
Roof not showing all layers of sructure in some sections
Fri, Sep 15, 2017 at 1:25:04 AM
11
Removed Banked angle from sloping Pads
Tue, Nov 3, 2015 at 4:17:31 AM
WISHLIST - Cranked Sections
Thu, Apr 10, 2008 at 2:31:15 PM
perspective angle
Thu, Mar 29, 2012 at 7:43:10 AM
Intersecting sections tags not showing up?
Thu, Jan 11, 2007 at 2:44:49 AM
Page generation time: 0.2753
