2 Users Online (0 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Halftone Profile Lines
Tue, Jul 12, 2011 at 11:37:33 AM | Halftone Profile Lines
aaltoid
I have an elevation view that shows existing buildings in the background, and a proposed building in the foreground. The intent is to "ghost" the existing buildings so that the proposed building is pronounced. I have explored adjusting the halftone settings of each Revit-linked building, even going all the way to "0" on the brightness scale... but I'm not too happy with how the profile lines are turning up gray, or even white.
Is there a way to manipulate the settings so that the colored surfaces will gray out, while the profile lines remain black?
We are trying to avoid doing a Photoshop "cut-and-paste" job, but it's looking like that route is inevitable.
Tue, Jul 12, 2011 at 11:37:48 AM | Halftone Profile Lines
aaltoid
I'm using Revit 2011.
Tue, Jul 12, 2011 at 12:30:08 PM | Halftone Profile Lines
Instead of using the halftone, you might look at setting the VG for these models.
Revit MEP 2012 - Halftone not Working...
Fri, Oct 5, 2012 at 12:47:21 PM
Room Separation Lines showing up from lower levels as halftone
Wed, Dec 22, 2010 at 12:17:20 PM
RVT 9.1 - plotting as PDF changes lines to halftone
Tue, Jul 24, 2007 at 3:54:18 PM
Design Options Halftone?
Tue, Nov 20, 2018 at 10:58:56 PM
Halftone Wall Reveal
Thu, Feb 27, 2014 at 4:23:02 PM
Page generation time: 1.9634
