Forums >> Revit Building >> Technical Support >> Patterns
Wed, Nov 23, 2005 at 9:26:30 AM | Patterns
cescu70
cescu70 Avatar
Hi everybody from Italy, I wish to know in which file I have to put the pattern I download? Thanx Francesco
Wed, Nov 23, 2005 at 5:47:16 PM | RE: Patterns
eldados
eldados Avatar
4.5 Stars: 8 Votes
Francesco, you have 2 options: 1- load the patten as you create a new one (by duplicating existing) 2- under your revir install normally CPuhrogram FilesAutodesk Revit Building 8.1Data there is a file called "Revit.pat" if you open it it's just a text file, open your downloaded .pat and copy and paste into your revit.pat, but if you don't know what you are doing stick to option 1 Smile ALWAYS BACKUP YOUR FILE BEFORE EDITING! HTH
Integrator
KarelCAD
Tue, Nov 29, 2005 at 5:37:21 AM | RE: Patterns
cescu70
cescu70 Avatar
Thank you very much, I do the second option. Ciao from Italy
Where do model patterns go?
Thu, Sep 24, 2015 at 9:37:41 PM
create/ convert hatch patterns (.pat) to revit fill patterns
Tue, Jun 2, 2015 at 11:29:00 AM
Material cut patterns
Mon, Sep 19, 2016 at 8:56:36 PM
No Surface Patterns in Perspective
Thu, Feb 1, 2007 at 4:55:53 PM
Custom Hatch Patterns
Thu, Dec 23, 2004 at 3:00:32 PM
Page generation time: 0.0672
