63 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> 3D dimensions . . . way too high
Fri, Jun 10, 2011 at 2:22:01 PM | 3D dimensions . . . way too high
gregroberson
gregroberson Avatar
I am placing some windows inside a RST 2011 basic wall.  I wanted to add dimensions in 3D.  The I could select the window and edit the tempaorary dims. to corrolate with the actual dimensoins.  However, the dimensoins string annotation is 50ft in the air. . . any idea why this would happen?
Greg
Sat, Jun 11, 2011 at 6:23:58 AM | 3D dimensions . . . way too high
4 Stars: 205 Votes
Just select the "Work Plane" to the face of that wall, then use the Dim tool
Mon, Jun 13, 2011 at 11:47:07 AM | 3D dimensions . . . way too high
gregroberson
gregroberson Avatar
Fantastic! Thank you very much!
Deleted dimensions, door tags and window tags
Wed, Jul 18, 2007 at 10:57:29 AM
Small DIM and ANGLE
Thu, Nov 23, 2006 at 11:32:53 PM
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:36 PM
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:08 PM
Changing Dimensions
Mon, Feb 7, 2011 at 9:02:52 AM
Page generation time: 0.1530
