Forums >> Revit Building >> Technical Support >> Topography problem
Sun, Jun 5, 2011 at 6:46:59 PM | Topography problem
ranjith
I can see my model below the topography line in elevation. Does any one know how to fix it?
Mon, Jun 6, 2011 at 7:28:03 AM | Topography problem
Do you mean in an elevation or section view?  If so, goto the Massing & Site tab, the Model Site pulldown arrown and set the elevation of your poche base as well as the section cut material.
Tue, Jun 7, 2011 at 12:49:52 AM | Topography problem
ranjith
http://screencast.com/t/1PSfZCJqsG
Here is the screen shot. What part did I need to change?
Tue, Jun 7, 2011 at 7:06:56 AM | Topography problem
How about a screen shot explaining your problem?  Your topo settings look right so I don't understand your problem.
Tue, Jun 7, 2011 at 7:58:30 AM | Topography problem
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Here my problem ( I did attach pic hope it works )
Revit 2018........
Tue, Jun 7, 2011 at 8:08:20 AM | Topography problem
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
http://screencast.com/t/hUsTt3ZVh3t4
Revit 2018........
Tue, Jun 7, 2011 at 8:13:40 AM | Topography problem
This is an easy one.  You don't have site/topography on in VG.
Tue, Jun 7, 2011 at 8:16:33 AM | Topography problem
Or... your elevation does not cut your site.
Tue, Jun 7, 2011 at 5:22:46 PM | Topography problem
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
I see so the elevation view (icon) must be in the topography but now this is showing a cut through like a section showing earth fill there was a way to change this in the VG settings but I cant remember how. Hoping you do...
Revit 2018........
Wed, Jun 8, 2011 at 11:25:16 AM | Topography problem
As I responded earlier:> "If so, goto the Massing & Site tab, the Model Site pulldown arrown and set the elevation of your poche base as well as the section cut material."
Wed, Jun 8, 2011 at 5:42:20 PM | Topography problem
#11
Jamie351
Jamie351 Avatar
4 Stars: 7 Votes
Yeah that works only thing is it does it for the section aswell when I want to see the fill.
Revit 2018........
TOPOGRAPHY SPLIT PROBLEM
Mon, Sep 22, 2008 at 2:51:42 PM
TOPOGRAPHY PROBLEM
Wed, Jan 27, 2010 at 10:47:10 AM
problem pads and subregions , weird depression on topography
Sun, Mar 22, 2015 at 1:46:45 PM
Topography
Wed, Oct 19, 2016 at 6:19:21 AM
Topography dissapearing
Wed, Nov 7, 2012 at 2:46:15 PM
Page generation time: 2.3829
