76 Users Online (74 Members):
Forums >> Revit Structure >> Technical Support >> Cannot Use Work Plane Error
1 Posts No Rating |
Howdy!
I was hoping someone could enlighten me on how to get this error to go way. I get the error when I attempt to add my roof deck using the floor tool. I have tried setting the work plan to the level I am working in, but it didn’t seem to matter.
The model was working at one time and I was able to add the roof deck. However, I deleted the deck and when I tried to put it back it, this error showed up.
Any thoughts??
Are you in a "Plan View" or other view like Elevations or sections views?
If you look at the "Ribbon" you will see at "Home" tab the "Set Work Plane" button, that's a "Blue Square" with a vertical and horizontal grid...
It is also important to name the workplane, because if you name it and then look at it in a 90 degree view, you can use the framing view tool and it will instantly give you a parallel view. If you don't name the view the framing view tool will not work.
Work Plane Error |
Thu, Nov 5, 2009 at 8:41:13 AM
Floor & Work Plane Error Message |
Thu, May 4, 2017 at 8:01:02 PM
Editing Work Plane for Component |
Tue, Nov 23, 2010 at 2:04:10 PM
Set roof or soffit on work plane? |
Mon, Dec 2, 2013 at 12:57:49 PM
14
get rid of current work plane and 3D snapping |
Fri, Nov 10, 2006 at 3:26:52 AM
