Forums >> Revit Building >> Technical Support >> Elevation Tags
Wed, Mar 16, 2011 at 4:33:31 PM | Elevation Tags
morss
Does anyone know why Revit 2011 will not let me load a different elevation tag than the one it comes with? Or better how can I load a different elevation tag in Revit 2011 than the one it comes with?
Morss Medical Architecture
Thu, Mar 31, 2011 at 5:09:25 AM | Elevation Tags
tossaxe
It should =]
Load your desired elevation symbol in to the project.Then select the default elevation circle and hit "Edit type"Change the "Elevation Tag" to the one you need
Hope it helps Winking
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
Elevation Tags
Tue, Oct 23, 2007 at 4:30:06 PM
Custom Elevation Tags
Thu, Mar 17, 2011 at 5:09:02 AM
2011 interior elevation tags
Thu, Dec 23, 2010 at 11:44:57 AM
Multiple Elevation Tags
Mon, May 24, 2010 at 3:20:16 PM
Page generation time: 0.4758
