Forums >> Revit Building >> Technical Support >> How to model a window from dwg file?
Tue, Mar 15, 2011 at 3:24:28 AM | How to model a window from dwg file?
shenlunglinnk
3 Stars: 2 Votes
Hi
I imported a pyramid-shaped skylight window from Autocad.
I tried to import this dwg file to "family", and chose "metric window", then up load it to my project.
This maybe work, but it can not be schedule properly.......
What is the best way to model it in Revit since all the frames and glass are not regular forms?
Thank you :-)
Tue, Mar 15, 2011 at 5:56:33 AM | How to model a window from dwg file?
4 Stars: 205 Votes
Don't do that, Autocad or Sketchup files are "Dumb" objects, you cannot manipulate them in Revit, so, read the tutorials and create your window like you want: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=13376394
Tue, Mar 22, 2011 at 9:19:44 AM | How to model a window from dwg file?
shenlunglinnk
3 Stars: 2 Votes
Thank you very much :-)
model a window in revit from dwg
Sat, Apr 4, 2009 at 6:03:34 AM
Revit Not Cutting Through Imported .dwg 3D Model
Mon, Jan 19, 2015 at 2:05:11 PM
Importing Sketchup file as dwg
Mon, Oct 28, 2019 at 12:12:18 PM
How to show a correct section of a linked dwg model
Wed, Sep 18, 2013 at 8:08:10 AM
DWG and Filled/Masked Region???
Thu, Jun 7, 2012 at 2:18:16 PM
Page generation time: 2.8406
