7 Users Online (5 Members):
Forums >> Revit Building >> Technical Support >> Curtain walls
6 Posts No Rating |
For some unknown reason, my curtain walls are thick as hell. I can't get into any editor to change that. I enven looked in the management tab without success. I tried to make a different wall and choose a 1 layer material: glass. Unfortunately i can't add a mullion to it. I tried copy pasting from other project, but it changes to the thickness in the current project. I googled it and seems either i didn't choose the right words or no1 has runned into this kind of situation before. Any suggestions/ sollutions?!
"For some unknown reason, my curtain walls are thick as hell." - Are you talking about the thickness of the glass?? If so, just select one panel (use the TAB key if you need) go to properties>edit Type and change that.
6 Posts No Rating |
This is not a standard wall, it is a curtain wall. And yes i was talking bout the glass thickness In revit 2011, you cannot edit the thickness. Maybe you can tell how to edit the keynote, that might help
"And yes i was talking bout the glass thickness In revit 2011, you cannot edit the thickness." - Who told you that? Again:..... just select one panel (use the TAB key if you need) go to properties>edit Type and change that.
Edited on: Fri, Mar 11, 2011 at 12:31:15 PM
6 Posts No Rating |
Oh, i dont have that.
And sorry about my tone, now i see it was a bit rude(alot actually)
I couldn't do that. Insted i moved the entire project to another file which had a normal thicknes of the curtain wall. That did the trick.
Ty and sorry
Angled Curtain Walls - fillets and nested |
Thu, Apr 23, 2009 at 5:42:47 PM
Curtain walls |
Mon, Nov 7, 2011 at 10:28:33 AM
Curtain Walls |
Wed, Apr 16, 2008 at 1:30:46 PM
curtain walls in legends |
Tue, Feb 23, 2010 at 9:50:09 AM
14
solid walls transparent to curtain walls and railings in back.. |
Mon, Oct 29, 2012 at 7:34:26 AM
