Forums >> Revit Building >> Technical Support >> Cut soild with 2 voids
Tue, Mar 8, 2011 at 3:08:34 PM | Cut soild with 2 voids
precast100
I need to cut a 2'-0" x 1'-8" solid with 2 different voids.
or is there a better way.
Once I cut the solid the bottom is not all in the same plane.
See attached PDF of what the final product needs to be.
Thanks
A Problem with Voids
Fri, May 18, 2012 at 8:41:19 AM
Cut Roof with VOIDS
Tue, May 27, 2014 at 8:01:33 AM
Voids in Array cuts all elements, instead of only some
Tue, Jan 22, 2019 at 4:09:02 PM
Wall by face on curved solid - VOIDS not seen
Mon, Jul 29, 2013 at 1:29:54 PM
Cutting with Voids outside of families
Wed, May 23, 2012 at 7:53:29 AM
Page generation time: 0.4907
