76 Users Online (75 Members):
Forums >> Revit Building >> Technical Support >> AccuRender
Hi
I am trying to add a stone effect to a certain wall I have created. I am not a very experienced user of revit and am therefore having trouble doing this. Under materials and then AccuRender I have found a stone effect which would work. I do not know however how to apply this to the finish of the wall. I have tried editing the wall structure and edited the finish and selected the AccuRender option I wanted but it did not work.
Any help Appreciated
i had the same issue - see the following thread
http://www.revitcity.com/forums.php?action=viewthread&thread_id=1221
Will
Place jpeg/bmp in Revit rendering/materials folder. (application data/autodesk/revit_?/rendering/accurenderredist/support/material)
(? is version of revit you are using)
Go to maps tab, and Add
Go to above location and select your material
OK twice and save as a User material
I got to this bit however when I went to add I could not find the location as it was searching by picture formats and would not let me change it. Could you either explain it a bit more clearly or is there another way?
Cheers
the stone effect only appears in your rendered view, just make sure you are aware of that?
Accurender ground cover |
Wed, Feb 22, 2006 at 2:08:03 PM
Accurender |
Fri, Dec 1, 2006 at 6:34:49 AM
Adding new materials to accurender library |
Thu, Nov 19, 2009 at 5:44:18 AM
Accurender nXt for Revit. Alpha version available. |
Wed, Apr 8, 2009 at 10:05:55 AM
ACCURENDER |
Mon, Feb 19, 2007 at 3:16:52 PM
Members: | 1991482 | Objects: | 22879 | Forum Posts: | 152184 | Job Listings: | 3 |
