45 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Multi Leveled floor in Revit
Fri, Feb 4, 2011 at 10:27:14 AM | Multi Leveled floor in Revit
usf85
i am kind new to revit i am working on project where the ground floor is multileveled reanges from +1m to - .75m
and i want to be able to show all of them on one level in the plans and etc ...
i tried to put a level for every level but revit treats it as if its seprate floor
Fri, Feb 4, 2011 at 11:43:32 AM | Multi Leveled floor in Revit
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
you can use a different level for each floor if you like. And you may find that you will want to use plan regions to view to use different view limits.
Fri, Feb 4, 2011 at 12:45:16 PM | Multi Leveled floor in Revit
You will want a seperate level for each of these but you can show them all in any one view by adjusting your view range.
Th reason why you will need seperate levels is for hosting.
Editing Multi-Level Building
Wed, Jul 20, 2011 at 11:11:04 AM
Multi Level 3d into Single Level 3d
Thu, Jun 18, 2009 at 2:02:02 PM
Using Revit for multi-level alternate
Tue, Apr 29, 2014 at 11:16:33 AM
multi floor building
Mon, Sep 22, 2014 at 7:29:45 AM
linked models by floor - multi story wall elevation
Mon, Aug 23, 2010 at 4:08:29 PM
Page generation time: 1.4897
