8 Users Online (6 Members):
Forums >> Revit Structure >> Technical Support >> Section Cut Quandry
5 Posts No Rating |
Section cuts on a second floor framing plan produce an error message reading "none of the created elements are visible in Structural Plan: Level 2 view. You may want to check the active view, its parameters, and visibility settings, as well as any plan regions and their settings." The section IS created on the level above and below - but not the middle level. And when viewing the section, I see the Level 2 framing. It just won't place a section mark on that Level 2. I assume I have some setting wrong, but don't know where to start. Thanks much!
check scale of plan view and check to see if the section marks have been turned off in that particular plan view. Section marks can be set not to show up in smaller scales. Section markes can be turned off, and on in VG.
5 Posts No Rating |
Scale is set as on the other levels (1/8" - and we tried changing the scale for that level to 1/4" to no avail. And I confirmed that the sections are turned 'on' within VG - annotations tab.
did you accidentally hide them check for hidden objects witht the " reveal hidden objects light bulb at the bottom of the screen."
5 Posts No Rating |
good thought - but that doesn't appear to be the case. I tend to think i have some setting wrong.
5 Posts No Rating |
I was able to resolve this particular issue by applying the View Template from the level below to the problem level. Presto! it's fixed. Still unsure on why the problem existed in the first place, but this is a swell work-around.
Cut Pattern in Plan vs Section |
Tue, Aug 25, 2009 at 8:47:59 AM
Sections cut on mulitple sheets |
Fri, Jun 27, 2008 at 12:33:38 PM
Is it possible to not have the bold section cut lines |
Thu, Apr 3, 2008 at 12:58:16 PM
Segmented section cut |
Wed, Oct 10, 2007 at 1:19:40 PM
Animate section cut? |
Sat, May 29, 2010 at 5:15:48 AM
