Forums >> General Discussion >> Wishlist >> Convert Lines
Tue, Jan 25, 2011 at 12:31:53 PM | Convert Lines
skromer
Why can you only convert lines from detail to model in plan and not in elevation?
Tue, Jan 25, 2011 at 12:36:42 PM | Convert Lines
TKennedy
4 Stars: 8 Votes
You should be able to do that. Model lines need a work plane, so make sure your elevation view is set up correctly.
Tue, Jan 25, 2011 at 12:39:53 PM | Convert Lines
An elevation does not have a set workplane whereas a plan does.  Set an appropriate workplane to host your line on and the detail line will then convert.
Tue, Jan 25, 2011 at 5:03:38 PM | Convert Lines
skromer
Thank you this makes sense.
Can you convert model lines to detail lines?
Wed, Mar 31, 2010 at 12:45:23 PM
Can we convert lines to pipes? (Revit MEP)
Tue, Aug 28, 2007 at 9:26:18 AM
Can I convert detail lines to model lines
Tue, Jul 29, 2008 at 3:03:49 AM
CONVERT RHINO TO REVIT
Thu, Feb 13, 2020 at 5:10:11 AM
Changing from Model to Symbolic Lines
Fri, Mar 6, 2009 at 2:13:30 AM
Page generation time: 0.6719
