Forums >> Revit Building >> Technical Support >> Changing a wall hosted component to non-hosted?
Sun, Jan 23, 2011 at 9:43:18 AM | Changing a wall hosted component to non-hosted?
AndyNH
Hi all,
I created a screen door family. I used a door template to start.  Now it looks for a wall to host it.  However, I'm using my screen doors as panels in a three-season porch.  So there's not really a wall to host it because I'm using closely spaced posts to maximize unobstructed views. Is there an easy way to change the family so it doesn't look for a wall?
 -AndyNH
Sun, Jan 23, 2011 at 10:02:04 AM | Changing a wall hosted component to non-hosted?
Sorry but there is no way to change hosted to non-hosted.
BUT  This is so easy your gonna shoot yourself.... Why aren't you using a wall anyawy?  This is where you really have to think Revit's way.  What you are creating is a wall and you are using a door.  Yes, most of the wall is opened up, but it is still a wall.  Your screened in areas should be "windows" and what is below your windows and above them, the door and your windows is your framing .... the wall.  So now you just have to create those screens... I mean windows.
Have fun
Sun, Jan 23, 2011 at 10:28:30 AM | Changing a wall hosted component to non-hosted?
AndyNH
Thank you WWHub. You make an excellent point.  Sometimes you gotta learn things the hard way.  For others who may have traveled this errant path...
I did find that in Revit 2011, you can copy your geometry/parameters from a one hosted component to a new differently hosted family type.  Some parameters did not stick, but were relatively simply to fix in the new family.
However, as WWHub suggest... I'm discarding my new creation (in this case I had made it floor hosted) and conforming to Revit terms...
Changing Wall Hosted components
Wed, Aug 1, 2007 at 9:47:34 AM
Wall hosted or Surface hosted
Mon, Sep 26, 2016 at 3:40:49 PM
Coverting wall hosted to face hosted familys
Wed, Jun 23, 2010 at 6:11:07 PM
Wall Hosted Cut Wall Line Weights
Tue, Oct 20, 2009 at 8:13:34 PM
Wall hosted Families
Wed, Feb 11, 2009 at 7:29:20 AM
Page generation time: 3.4928
