471 Users Online (11 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Building >> Technical Support >> PROBLEMS EXPORTING GRAPHIC COLUMN SCHEDULE TO AUTOCAD
Thu, Jan 20, 2011 at 11:25:36 AM | PROBLEMS EXPORTING GRAPHIC COLUMN SCHEDULE TO AUTOCAD
MADnes
I AM HAVING PROBLEMS EXPORTING MY GRAPHIC COLUMN SCHEDULE TO AUTOCAD FROM REVIT STRUCTURES 2011. WHEN I EXPORT IT THE RESULT IS MY COLUMNS AND TAGS ARE THE ONLY THINGS EXPORTED. THE TABLE AND TABLE HEADINGS ARE MISSING. I HAVE TRIED TO FIGURE OUT WHAT LINE TYPE I MAY BE MISSING IN MY EXPORT TRANSLATION, BUT I HAVE BEEN UNSUCCESSFUL THUS FAR. I HAVE EVEN TRIED TO EXPORT USING THE STANDAR AIA TRANSLATION, WITH THE SAME RESULT.
Gabriel Flores AAS/CDD, BS/CM
Thu, Jan 27, 2011 at 12:23:31 PM | PROBLEMS EXPORTING GRAPHIC COLUMN SCHEDULE TO AUTOCAD
mholzer
4 Stars: 1 Votes
I have the same problem.  I am not sure why the schedule does not export.
I do have a workaround given to me by Melinda Beham on AUGI:
Freeze the column schedule using the "Freeze Drawings" command in the Revit Extensions.  This will create a drafting view that you can export to AutoCAD and the entire schedule will export.
Grid lines from link outside of crop area
Mon, Jun 27, 2011 at 1:49:59 PM
Creating Families
Wed, Sep 24, 2008 at 5:06:16 PM
schedule - item count
Fri, Oct 31, 2008 at 2:49:47 PM
11
Revit Architecture 2013 - Known Issues
Fri, Apr 6, 2012 at 7:02:23 AM
Graphical Column Schedule - Formatting
Tue, Jan 9, 2007 at 12:57:38 PM
Page generation time: 0.3936
