Forums >> Revit Building >> Tips & Tricks >> Glass Ceiling
Thu, Jan 13, 2011 at 9:26:30 AM | Glass Ceiling
cboersen
I'm somewhat new to Revit so maybe this is nothing new.
 I had to suspend some lights out in the middle of a space far below the ceiling but these lights had no offset ajustment.  I created a clear glass ceiling at the appropriate height and attached my "suspended" lights to it.  The lights are at the correct height and you can not see the clear ceiling.  Perhaps there is a better way but this worked great.
Thu, Jan 13, 2011 at 4:28:23 PM | Glass Ceiling
rkitect
rkitect Avatar
4 Stars: 29 Votes
Actually, there is a way to do this that is not even a workaround. Just open the light family and create an adjustment parameter. You ould of course make a light that is non hosted so that you can simply hang it in space, but then you have to explain to the owner why all his lights were sitting on the floor after the contractor was done.
No a much better solution is to open th family up and create an adjustment that allows you to set teh height of the light source while leaving the host position where it's at. Make sense? Questions on how to do this?
Fri, Jan 14, 2011 at 6:48:23 AM | Glass Ceiling
cboersen
Thank you for the help.  I would love some help on how to add an adjustment because I have no idea.
 Not more rhymes now, I mean it.  Anybody want a peanut?
Fri, Jan 14, 2011 at 9:01:31 AM | Glass Ceiling
rkitect
rkitect Avatar
4 Stars: 29 Votes
I'll make a video, but it may be later tonight before it's up.
Which light family are you using?
Edited on: Fri, Jan 14, 2011 at 9:01:43 AM
Fri, Jan 14, 2011 at 12:13:49 PM | Glass Ceiling
cboersen
Not a problem.
http://www.revitcity.com/downloads.php?action=view&object_id=744
http://www.revitcity.com/downloads.php?action=view&object_id=1609
 Thanks a lot.
Creating a glass ceiling
Sun, Mar 3, 2019 at 2:45:07 PM
Floor to Ceiling Windows/glass wall
Tue, Dec 18, 2007 at 8:24:21 PM
Transparency of glass windows in 3d views
Wed, Aug 5, 2009 at 10:43:37 AM
Rendering glass with pattern 2009
Mon, Oct 13, 2008 at 3:27:21 PM
Glass behaving oddly
Thu, Nov 27, 2014 at 11:05:47 PM
Page generation time: 0.3158
