Forums >> Revit Structure >> Technical Support >> Copy/Monitor Walls Creates Too Many Family Types (REVIT Structure 2011)
Wed, Jan 12, 2011 at 7:28:18 PM | Copy/Monitor Walls Creates Too Many Family Types (REVIT Structure 2011)
Chazbo
Let's say I try to copy/monitor 4 walls (each of the same arch'l wall family) from arch'l to struct'l REVIT (2011).  In the options menu I instruct REVIT Structure to "Copy original Type".  Instead of REVIT Structure creating 4 walls of the same family type, it creates one family for each wall (4 families total) even though I started with one original arch'l wall family.  So four arch'l walls of a single family type F2e become four structural walls of family types F2e, F2e-1, F2e-2 and F2e-3.  What is the trick to get all 4 walls to be of one family type?  Thanks in advance.
Chuck George, George Structural Drafting, LLC - Orange, CA
Thu, Jan 13, 2011 at 4:32:39 PM | Copy/Monitor Walls Creates Too Many Family Types (REVIT Structure 2011)
rkitect
rkitect Avatar
4 Stars: 29 Votes
This is interesting. I've worked with Copy/Monitor extensively and have not seen this happen. Do you get a dialog that informs you a type of that name already exists or that it is renaming the type to avoid conflict?
I'm going to have to test this out and see what I get for result.
Thu, Jan 13, 2011 at 4:42:22 PM | Copy/Monitor Walls Creates Too Many Family Types (REVIT Structure 2011)
Mhill1976
The problem is that you're using the "Copy Original Type" in the copy/monitor options when you should be Transferring Project Standards of the wall types in the Arch file and matching those types in the copy/monitor options.  Once you do that, the walls will all come out as the same type.
Thu, Jan 13, 2011 at 4:56:39 PM | Copy/Monitor Walls Creates Too Many Family Types (REVIT Structure 2011)
rkitect
rkitect Avatar
4 Stars: 29 Votes
That is one way to do it Mhill, but the "Copy Original Type" is the prescribed workflow for this. Why would a structrual engineer want to bring in the wall types that are in the architectural model just for the one or two that they need?
Check this video and let me know what I'm doing differently from your work process:  http://screencast.com/t/ig6ELHfx
HTH.
Fri, Jan 14, 2011 at 7:14:11 AM | Copy/Monitor Walls Creates Too Many Family Types (REVIT Structure 2011)
Mhill1976
The structural engineer doesn't need to bring in all of the wall types, but it is impossible to perform a Coordination Review with your prescribed method.  One can copy and paste from the Arch. only the wall types that are needed, but should never use Copy Original Type if they are planning on coordinating with another model, which Revit is intended for.
Fri, Jan 14, 2011 at 8:51:08 AM | Copy/Monitor Walls Creates Too Many Family Types (REVIT Structure 2011)
rkitect
rkitect Avatar
4 Stars: 29 Votes
Um, not impossible. We do it all the time on every project in our office, and every office I've implemented in the past. Copy Original Type is exactly how coordination hapens across models. There is nothing tedious or hazardous to the model about this method and is almost a step by step recall of how the product's User Manual describes this workflow.
I'll submit that there are some situations where copy original is not ideal, for instance if the wall type in archtiectural is CMU w/ Furring and Gyp and all the structural engineer needs is the CMU, but Copy Original can still be used in this case and modify the wall type so that all walls of this type are reduced to CMU only. In your method, how exactly
What exactly about this method makes it impossible to perform coordination reviews? Did you watch my video? Seems pretty plausible to me.
Fri, Jan 14, 2011 at 12:42:07 PM | Copy/Monitor Walls Creates Too Many Family Types (REVIT Structure 2011)
Mhill1976
It's a pain to copy/monitor walls that way because it adds all of those families to your model.  If you actually choose the type that you are copy/monitoring instead of "Copy Original Type", then you don't get the numbered wall families.  Our firm doesn't even copy/monitor walls anymore because it's so cumbersome and you never get the result that you're looking for.  Chazbo's original question was how to not get the numbered walls and I provided the correct answer.
Although, I do like the reference to "The Princess Bride" in your signature.
Fri, Jan 14, 2011 at 1:27:26 PM | Copy/Monitor Walls Creates Too Many Family Types (REVIT Structure 2011)
rkitect
rkitect Avatar
4 Stars: 29 Votes
The wall names in my video are because that's how they are named in the architectural. The point of my video is that Copy/Monitoring THE CORRECT way does not create duplicate wall types. The secondary point of the video was to confirm that that is indeed how they are doing copy/monitor to see if there's soemthing extra they are doing to get the duplicate wall types.
Chazbo asked "What is the trick to get all 4 walls to be of one family type?" and I provided a video with proof showing that correct copy/monitor does not result in dulpicate wall types each time you copy monitor.
In regards to your firm's practice, while that's one way to do it, it's far from more efficient. How do you get coordination alert? Do you use revit to automate the coordination? I'm assuming you do since you pointed out that Revit is intended for coordinating with revit. If so you'd have to manually pick each wall in your model and then tell revit which wall in the link it should monitor to. THAT is cumbersome.
Grinding the gears in a manual transmission may be more efficient since you leave out the step of using a clutch, but that doesn't make it the correct answer.
Thanks, I love that line Smile
Edited on: Fri, Jan 14, 2011 at 1:28:47 PM
Copy/ Monitor walls in 2011 or 2012
Thu, Jul 14, 2011 at 1:24:43 PM
best practice for copy/monitor
Sun, Dec 12, 2010 at 5:07:02 PM
Copy/Monitor Deleted Element Revit 2011
Sun, Aug 14, 2011 at 6:09:41 PM
Copy/Monitor walls
Tue, Apr 2, 2013 at 10:14:23 AM
Copying Arch Wall Types
Tue, Aug 14, 2012 at 9:18:26 AM
Page generation time: 6.7612
