Forums >> Revit Building >> Technical Support >> Slow Regen with ACAD DWG's
Fri, Mar 26, 2004 at 12:44:35 AM | Slow Regen with ACAD DWG's
ntwinter
I've imported a dwg file and exploded it so I can edit the linework. I have then constructed various Revit components in the drawing. Every time I pan/zoom the file now takes about 30-40secs to regen. This is a major problem when I'm trying to get the job done and have to sit and wait every time I pan around. What can I do?
Revit 2010 - Export to ACAD 2008 .dwg?
Wed, May 6, 2009 at 2:07:20 PM
Exported file to ACAD has problems with custom PATTERNS [made in acad]
Mon, Jun 23, 2008 at 3:21:32 PM
line weights problems corresponding to ACAD ref files
Tue, May 4, 2010 at 8:37:29 AM
Topo Surface using ACAD dwg
Fri, Jul 7, 2006 at 2:13:08 PM
Solution 2D DWG to REVIT Pls
Sun, Jun 18, 2006 at 6:04:13 AM
Page generation time: 0.4755
