Forums >> Revit Systems >> Technical Support >> Central File
Thu, Dec 30, 2010 at 12:30:15 PM | Central File
zkame
I am having difficulty with central files.  What we are trying to do is a build-out of a previous project we have worked on, how do you take the central file of the shell space and save it as a new file for teh build-out without messing up any information.  We are having trouble with the local files saying that they can no longer find the central file.
Any help will be appreciated,
Zach
Thu, Dec 30, 2010 at 1:27:00 PM | Central File
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
well, once a file is workshared, it can't be undone.
So, when you want to make a new central file, you need to go to "save as" and down at the bottom of your typical save-as screen, there's a button called "options."   Hit that, and select "make this file a central file after save"  and it'll become its own project, disassociated from your original project.
Hope that helps.
detach from central file
Wed, May 12, 2010 at 12:28:23 PM
can't save as a central file
Wed, Sep 9, 2009 at 2:35:47 PM
Opening a File Detached From Central
Wed, Oct 25, 2006 at 4:06:42 PM
can't view file properties - central path
Fri, Aug 21, 2009 at 2:34:53 PM
How do i know its a Central File?
Tue, May 8, 2012 at 8:42:22 AM
Page generation time: 0.4297
