Forums >> Revit Building >> Technical Support >> Wall pattern scaling, Revit Architecture 2011
Mon, Dec 27, 2010 at 5:05:15 PM | Wall pattern scaling, Revit Architecture 2011
modellwerke
I have imported the ACAD patterns (ANSI) that we use for wall type patterns, but unlike ACAD they do not scale correctly. I.E. when I do enlarged plans. Say my floor plan is at 1/8" scale and my enlarged restroom cores are 1/2" scale. The 1/2" scale enlargement patterns are very close to each othe proportionately.
I tried the;%type=model suggestion, but to no avail.
Any ideas?
Mon, Dec 27, 2010 at 6:23:52 PM | Wall pattern scaling, Revit Architecture 2011
All model patters will scale correctly with the model .... that has nothing to do with the view scale.  In otherworde, if the pattern is CMU, 8x16 units, they will always be model scale 8x16.  Drafting patterns are always fixed scale to paper space.  If you want different paper space scaled patterns, you need to load the drafting pattern at a different scale and name it accordingly.
Scaling fill pattern
Thu, Nov 17, 2011 at 4:01:24 PM
Fill Pattern at TOP of wall?
Wed, Nov 25, 2020 at 10:15:58 AM
Using 3D Studio Objects in Revit Architecture 2011
Tue, Sep 20, 2011 at 12:09:53 AM
Re-installing Revit Architecture 2011
Tue, Dec 13, 2011 at 1:26:18 PM
I Can't use RPC content in Revit Architecture 2011
Fri, Jun 4, 2010 at 9:46:20 AM
Page generation time: 3.4905
