Forums >> Revit Building >> Technical Support >> Revit 10 Architecture CZECH 64bit crash after click to display full ribbon
4 Posts No Rating |
I have trouble with Revit 10 Architecture CZECH language version 64bit under Windows 7/64b Home Premium. When I click to menu for display full ribbon option, Revit stay unstable and Windows must close it (as you can see at video). This was happen after right click to any place in top of the ribbon menu too (isn´t demonstrated in the video) http://screencast.com/t/38SPR8X2ETcc In the system log are a kernel error warnings and before this a DOTNET warning was displayed: http://screencast.com/t/0Jw654xHcm .NET Runtime version 2.0.50727.4952 - Failed to CoCreate profiler. Názov chybovej aplikácie: Revit.exe, verzia: 2010.0.2009.917, časová značka: 0x4ab2ba9c Názov chybového modulu: KERNELBASE.dll, verzia: 6.1.7600.16385, časová značka: 0x4a5bdfe0 Kód výnimky: 0xe0434f4d Odstup chyby: 0x000000000000aa7d Identifikácia chybného procesu: 0xd08 Čas spustenia chybnej aplikácie: 0x01cba5baee2ba779 Cesta chybnej aplikácie: C:\Program Files\Autodesk Revit Architecture 2010\Program\Revit.exe Cesta chybného modulu: C:\Windows\system32\KERNELBASE.dll Identifikácia hlásenia: 6e15dcbf-11ae-11e0-8c07-001b247f35f7   sorry for national language words in the error log)
First install the Web Updates for Revit then check if the problem persists.
4 Posts No Rating |
I have this update installed: Autodesk Revit Architecture 2010 Update 2_64-bit (exe – 94.1 MB) but no change
I have not seen any Web Update installed in that video but check this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15859629&linkID=9243099 and this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15040187&linkID=9243099
4 Posts No Rating |
But this is for Revit 11
Ohh, sorry, maybe this one: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13401936&linkID=9273944
4 Posts No Rating |
I think, that this isn´t problem with licensing server, but a menu or anything else... I will try install Revit 2011 ENG 64bit version, and this working on the same system fine, as you see in video Difference between Revit 2010 CZECH 64 bit vith Service Pack 2 installed and Revit 2011 ENG 64 bit: http://screencast.com/t/gZ11rRzk0T4W Windows Error log - Applications: Názov chybovej aplikácie: Revit.exe, verzia: 2010.0.2009.917, časová značka: 0x4ab2ba9c Názov chybového modulu: KERNELBASE.dll, verzia: 6.1.7600.16385, časová značka: 0x4a5bdfe0 Kód výnimky: 0xe0434f4d Odstup chyby: 0x000000000000aa7d Identifikácia chybného procesu: 0x894 Čas spustenia chybnej aplikácie: 0x01cba5de7e5d6d6b Cesta chybnej aplikácie: C:\Program Files\Autodesk Revit Architecture 2010\Program\Revit.exe Cesta chybného modulu: C:\Windows\system32\KERNELBASE.dll Identifikácia hlásenia: 2737aa85-11d2-11e0-8c07-001b247f35f7 Názov chybovej aplikácie: WSCommCntr2.exe, verzia: 3.0.268.0, časová značka: 0x4b8f1b64 Názov chybového modulu: ntdll.dll, verzia: 6.1.7600.16559, časová značka: 0x4ba9b802 Kód výnimky: 0xc0000005 Odstup chyby: 0x000000000004cf54 Identifikácia chybného procesu: 0x1f7c Čas spustenia chybnej aplikácie: 0x01cba5de7380f6e5 Cesta chybnej aplikácie: C:\Program Files\Common Files\Autodesk Shared\WSCommCntr\lib\WSCommCntr2.exe Cesta chybného modulu: C:\Windows\SYSTEM32\ntdll.dll Identifikácia hlásenia: b1c00f93-11d1-11e0-8c07-001b247f35f7 .NET Runtime version 2.0.50727.4952 - Failed to CoCreate profiler.
Revit Link causes crash |
Wed, Dec 29, 2010 at 10:33:38 AM
Ribbon Issues |
Tue, Jan 14, 2014 at 9:51:50 AM
revit architecture 2012 missing ribbon tabs |
Tue, Sep 17, 2019 at 8:13:49 AM
Books |
Mon, May 17, 2010 at 6:26:14 AM
Import full Civil 3D 2012 model in Revit Architecture 2012 |
Thu, Jan 26, 2012 at 6:23:35 AM
