Forums >> Revit Building >> Technical Support >> Site Topo with colour
Wed, Dec 22, 2010 at 1:36:25 PM | Site Topo with colour
iamian33
iamian33 Avatar
Greetings ...
Here is a curious one.  My designer wishes to present a site plan with the topography coloured - different colours for different elevaitons.  Please see the attached PDF.
  1. Is there a facility in Revit that will assist with identifying the different topography elevations by colour?
  2. Also could this be done for a section?
I suspect that Filled Regions will be the only way to go, but I don't look forward to tracing the contour lines to create the filled regions (don't know if I can trace contour lines).
Any strategies will be appreciated, thanks.
Ian Shafer
Principal Consultant
True North S&F Consultants
Wed, Dec 22, 2010 at 1:43:14 PM | Site Topo with colour
Export to CAD to get the linework, then either fill it in CAD and import (probably easier) or import the linework into seperate filled area sketches.
NOTE:  This is all only 2D.
Wed, Dec 22, 2010 at 1:58:56 PM | Site Topo with colour
iamian33
iamian33 Avatar
Can I imort CAD linework into a sketch mode?  I tried that once but had no success.
Ian Shafer
Wall on Topo Site
Wed, May 28, 2008 at 5:00:38 AM
RAC 2009 - Topo Site Work
Fri, May 9, 2008 at 3:08:34 PM
level elevation doesn't match elev point in topo / site plan
Wed, Dec 18, 2013 at 4:05:00 AM
13
topo. surfeaces
Thu, Jan 10, 2008 at 9:59:44 AM
Could Revit allow curb or sidewalk sweeps to be attached to site topo edges?
Wed, Apr 26, 2006 at 4:42:17 PM
Page generation time: 0.6815
