86 Users Online (84 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Room areas in Structure
Thu, Dec 16, 2010 at 7:55:19 PM | Room areas in Structure
hhwse
Is there any way to use the Room Area feature in Revit Structure?
Fri, Dec 24, 2010 at 12:42:40 PM | Room areas in Structure
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I use structure as well, and just looked into my most recent file regarding this question. On the ribbon under Architect & Site, there are three buttons which are grayed out one of which is area. I believe the problem is that you must create entire room bounding situations. Which are not the normal situation when you are doing structural drawings. That is no ceilings, and usually no doors or windows only openings. These can be drawn in structure, so that may be the answer. I also use Architecture and set my rooms up in there. Hope this helps.
Fri, Dec 24, 2010 at 8:08:38 PM | Room areas in Structure
hhwse
Revit structure does not have a ceiling feature.  can I use the room area without a ceiling?
room areas, room separations
Mon, Jun 2, 2008 at 8:19:42 PM
rooma area of several room areas
Mon, Apr 19, 2010 at 1:45:30 PM
Merging Room Areas
Mon, Jul 27, 2009 at 11:50:56 AM
room tags & areas
Fri, Mar 31, 2006 at 2:20:02 PM
Room Areas and Colour Schemes
Tue, Oct 21, 2008 at 3:51:29 AM
Page generation time: 0.6705
