3 Users Online (1 Members):
Forums >> Revit Building >> Technical Support >> Advice on showing door swing in elevation
Hi, I have a quick question regarding the standard way to display the door swing in elevation. Usually, this is shown as a dash < or > on the door, and this is set up in the Revit door families. The problem I have is that the lines which make up the swing symbol wont show dashed, as my elevation is 1:100 - the dashes only show up if the elevation is around 1:10, which is obviously way to large. How to people deal with this, is there some way of getting the dashes to show up in these lines that I have missed? Cheers.
As in all things REVIT, this is controlled by object styles. Manage tab/ object styles / model objects / doors/ Elevation swing - line pattern. You can change this to a different line that will show dashed at that scale. Once you have it set as you like, set it in your template.
REVIT 2014: Door Elevations - swing lines are shown backwards? [ 1 2 ] |
Tue, May 12, 2020 at 2:41:52 PM
16
Door swing not showing up on plan |
Fri, May 10, 2013 at 10:24:10 AM
3D Door Swing |
Fri, May 25, 2007 at 5:56:27 PM
Door Swing Question |
Mon, Oct 22, 2012 at 3:51:32 PM
12
Door family showing one thing in Family Editor another when placed into project. |
Mon, Aug 24, 2009 at 3:24:33 PM
