Forums >> Revit Building >> Technical Support >> Corrupt element
Sun, Nov 28, 2010 at 5:56:35 PM | Corrupt element
Mibro25
When I touch a element in Revit 2011, it says:Element 344449(not always the same number/element) became corrupt at some time before this session.  what can I do about it. When I so trying to save a recover fil, revit says: there is not enough space on drive C: to create the temporary files that revit needs. Either free up space on this drive, or redefine windows user variable TMP to be a folder another drive with more space. What Can I do about it ?
Mon, Nov 29, 2010 at 5:29:27 AM | Corrupt element
Mibro25
I found out a solution.
If u have the same problem, try to "save as" your file with another name.
Element's internal join data is corrupt
Mon, Jan 10, 2022 at 12:37:58 PM
Revit 2008 Error "Corrupt Element"
Fri, Sep 9, 2011 at 11:15:38 AM
Corrupt Elements Are killing US
Wed, Aug 22, 2007 at 12:35:38 PM
element 929000 corrupted
Mon, Apr 18, 2016 at 10:45:13 AM
CORRUPT FILE??!!**
Tue, Jun 24, 2008 at 12:43:36 PM
Page generation time: 0.7885
