Forums >> Revit Building >> Technical Support >> 2011 - Importing CAD - Error
Wed, Nov 24, 2010 at 3:36:33 PM | 2011 - Importing CAD - Error
narjes
Hi, I am trying to import a survey dwg to my Revit drawings, units are both in mm, but i get the following error and can not see the drawing except one random circlle - CAD file is on 0,0,0 point :
Imported objects located far from the model might not display properly. Revit will use the 'Cursor at center' option.
Thanks.
nsrjes
Thu, Nov 25, 2010 at 4:12:31 AM | 2011 - Importing CAD - Error
4 Stars: 205 Votes
Well, that's not an Error but a Warning and I don't understand when you said: "...and can not see the drawing except one random circlle..." - I'm looking your image and i'm watching (i believe) the CAD file.
Autocad 2011 Solid To Revit 2011 Mass floor error
Mon, Feb 28, 2011 at 7:20:10 AM
Importing CAD 3D
Sat, Mar 7, 2009 at 7:26:45 AM
importing cad problem
Fri, Mar 15, 2013 at 6:33:52 AM
Importing CAD Line Styles - Auto Convert?
Thu, Jun 14, 2012 at 4:04:27 PM
Importing a cad file
Fri, Apr 27, 2012 at 3:33:21 PM
Page generation time: 1.3553
