22 Users Online (21 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Technical Issues
Mon, Nov 1, 2010 at 11:10:33 AM | Technical Issues
mcdonaldkaitlynh
I'm having trouble with loading in my families. It's becoming a problem when I click on component to load something else and the last thing I loaded comes up. If i push escape it gets rid of it but the next time I try to load something in, even though I select it and select open, it still loads the last item put into the floor plan. Has anyone else experienced this and do they know a way around it? I've ben having to exit out of the entire program. I tried closing the project and re-opening it but the same thing happens still. What to do...
Mon, Nov 1, 2010 at 12:18:31 PM | Technical Issues
Your problem is caused because you are not in the correct view to place you last loaded item.  For instance, most furniture items can not be placed in an elevation view.
I bet this is a structural item.
Tue, Nov 2, 2010 at 8:21:56 AM | Technical Issues
mcdonaldkaitlynh
Well, I am always in first floor view because that is grade level. I can't use the 3D view or anything else evidently. I press component. The objects it was messing up with was a fireplace and a dining set. The fireplace was the last thing i put in and when I selected to place a dining table in, which i had done before with the same dining set, it caused that issue. I don't think the view was what was messing it up, thought that would be a factor.
Do we need to revamp technical forum?
Wed, Sep 22, 2004 at 3:06:24 PM
We Need a Project Management Forum for Project Management Issues/Information
Thu, Jun 17, 2010 at 12:33:05 PM
yet another issue with roofs
Wed, Jun 10, 2009 at 9:14:58 PM
Revit Family causing print issues
Wed, Jan 6, 2016 at 10:08:30 AM
Stage Trusses ( technical name?) for awning support in Revit 2013
Mon, Nov 18, 2013 at 7:57:26 AM
Page generation time: 0.4625
