Forums >> Revit Building >> Technical Support >> Lay pieces flat to print and cut actual size?
Fri, Oct 15, 2010 at 4:10:06 PM | Lay pieces flat to print and cut actual size?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello there,
I have a random question.  I am needing to build a model and I have some tilted roofs that are a bit  complicated and I am needing to layout my pieces so I can cut them on a laser cutter to assemble the model.
Any ideas?  Do I need to use another program?
Thanks,
Lorne
Denver, CO
Revit Architecture
Fri, Oct 15, 2010 at 4:19:32 PM | Lay pieces flat to print and cut actual size?
If you cut sections and rotate them so that they are parallel to each roof plane, you can get true "flat" layouts.  You would need one for each sloping roof plane.
Mon, Oct 18, 2010 at 9:18:14 AM | Lay pieces flat to print and cut actual size?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
oh, good thinking.
Thank you WWHub.  As always you've come through again!
Lorne
Denver, CO
Revit Architecture
Fri, Oct 3, 2014 at 1:19:13 PM | Lay pieces flat to print and cut actual size?
CH1N4
Hello, I'm trying to do the same thing but my roof is pitched in 2 directions. Any thoughts on how I would do this? I've tried aligning a section but it only aligns North/South but not East/West.
Thanks for the help.
Fri, Oct 3, 2014 at 1:50:58 PM | Lay pieces flat to print and cut actual size?
All sections can be rotated.  Vertically as well as horizontally.  Cut the section - go to a perpindicular elevation or section view and rotate the section there.
Fri, Oct 3, 2014 at 10:59:46 PM | Lay pieces flat to print and cut actual size?
CH1N4
Sorry. What I meant to say is that my roof is pitched in such a way that if looking from the floor plan view, the slope arrow goes north-west as opposed to north to south or east to west. The problem is I can rotate the section in the East or West Elevation but I need to rotate it again in the North or South Elevation.
I'm not entirely conviced that it can be done and I might just have to approximate it on my model.
Thanks for the input.
Sat, Oct 4, 2014 at 9:14:49 AM | Lay pieces flat to print and cut actual size?
My answer is still the same.  Try it out so you see how it works.   Then you will figure out what you need to do.
Sat, Oct 4, 2014 at 11:31:09 AM | Lay pieces flat to print and cut actual size?
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Adding to WW, when rotating the section, use ref planes - sections will snap to them.
Sat, Oct 4, 2014 at 7:08:22 PM | Lay pieces flat to print and cut actual size?
CH1N4
Ok, what I was trying to do was place a section and rotate it in the north elevation and then rotating the depth in the East Elevation which apparently you can't do. But now I see that I actually needed rotate it in plan view. That makes much more sense.
Thanks WW and pij for the help and the image and the patience. Smile
Titleblock issues
Thu, Nov 5, 2009 at 8:00:41 AM
Printing Families_shop drawings
Thu, Mar 27, 2008 at 7:10:33 AM
8 side pyramid lay-in ceiling. Help.
Tue, Aug 28, 2007 at 10:50:55 AM
spot elevations - lay-in ceiling
Thu, Oct 27, 2005 at 2:49:21 PM
Voids through multiple families
Sun, Mar 30, 2008 at 3:24:06 AM
Page generation time: 0.6827
