Forums >> Revit Structure >> Technical Support >> Ram-revit link problem
Wed, Oct 13, 2010 at 11:03:41 AM | Ram-revit link problem
revitmatt
Windows 7, Revit Structure 2011, Ram Import v3.4.0.0, RAM 14.02.01.00
Started new Revit model using our standard template.
Imported RAM model to Revit, no issues.
Engineer continued modeling in RAM.
Structural technician, myself, attempted to update RAM model.
Model updates...but leaves beams that were removed from the RAM model in place, adding others with revised spacing. Also, beams that the size was revised are copied on top of existing beams, with existing beams remaining.
 I have attempted this several times with the "Import as New Model" checked and unchecked. Tried again...the beam spacing revised itself this time. But revised beam sizes are still on top of existing beams.
Does anyone have any experience with the problem I am having that might help?
 Thanks,
 Matt
Ram Structure imports
Thu, May 31, 2007 at 1:17:14 PM
Ram Ram Ram
Tue, Jul 25, 2006 at 10:20:07 AM
RAM Model to Revit Structure 2012
Thu, Dec 1, 2011 at 5:37:09 AM
Revit 64bit & RAM
Tue, May 4, 2010 at 9:02:19 AM
Importing Ram Model
Thu, Feb 28, 2008 at 9:08:34 AM
Page generation time: 1.8273
