38 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Angular constraints problem
Thu, Sep 30, 2010 at 9:10:26 AM | Angular constraints problem
archie456
3 Stars: 1 Votes
Hi,
I seem to have a problem with pivot points and would appreciate some help.
I want to make a rotatable door leaf symbolic component which I will add to a door family to represent the leaf, I want to be able to make several family types which show the component at 0 degrees, 45, 90 and various other angles.
I’ve set up the component and linked constrained it with an angle parameter.
It works fine, apart from when I set the angle to 0, after this, when I set it to another angle the pivot point of the component moves away and messes up the door.
Any ideas why this is happening??
I cannot obviously make a door where the leaf keeps floating away!
Cheers.
Thu, Sep 30, 2010 at 9:26:25 AM | Angular constraints problem
TKennedy
4 Stars: 8 Votes
In my experience, families with rotating components like that do sometimes act a little wonky when you are testing in the family. However, once you get them into the project they act just fine. If it behaves like you want it to in the family with the exception of one angle (0° in your case), load it into a project and see if it works or not. I did that with your family, and it seems to work ok. I was able to change it from 45 to 0 to 90 just fine.
Thu, Sep 30, 2010 at 9:54:32 AM | Angular constraints problem
archie456
3 Stars: 1 Votes
yes - your right!!
It works fine in a project but goes wrong in the family editor.
Well, at least I can carry on now, just a shame I won't be able to check my family in the editor.
Thanks for your help.
Thu, Sep 30, 2010 at 1:00:19 PM | Angular constraints problem
TKennedy
4 Stars: 8 Votes
You should be able to do some checking in the family, there will just be one or two specific angles you will have to avoid.
Angular parameters
Tue, Sep 3, 2013 at 8:14:08 AM
showing angular dimensions in degrees seconds etc
Wed, May 5, 2004 at 7:43:16 AM
Angular surfaces
Fri, Oct 16, 2009 at 2:23:30 PM
ANGULAR DIMENSION TOLERANCE
Mon, Mar 2, 2015 at 1:00:50 PM
Family Type Constraints
Thu, Jul 5, 2012 at 10:55:10 AM
Page generation time: 1.1193
