Forums >> Revit Building >> Technical Support >> Imported family colors and shadows
Wed, Sep 29, 2010 at 1:31:44 PM | Imported family colors and shadows
samuelab
I've created a familly with materials (Metal and Mapple).
I've inserted it in a project.
For some reason the shadows and colors will not show once the familly is in the project, everything is just grey. Any idea why/how to fix it?
Thank you.
Wed, Sep 29, 2010 at 1:49:09 PM | Imported family colors and shadows
4 Stars: 205 Votes
Is that "Family" an imported object from CAD or Sketchup? or did you create that with solid extrusions and so on?
About the materials (grey), in your project > Materials check the "Names" and see if they have the materials you just assign in family.
About the shadows is wierd, can you post here some images where we can see the problem?
Wed, Sep 29, 2010 at 2:15:15 PM | Imported family colors and shadows
samuelab
Hello,
Thank for the quick reply. Here are the screenshots.
The familly was created in Revit. The Materials exist in the project and I checked "Use Render Appearance for Shading"
Wed, Sep 29, 2010 at 2:25:29 PM | Imported family colors and shadows
4 Stars: 205 Votes
Change the visual mode "Consistent Colors" to "Shaded with edges"
Wed, Sep 29, 2010 at 4:58:37 PM | Imported family colors and shadows
samuelab
That did not work, it looks the same in any view.
 I've attached the files.
Thu, Sep 30, 2010 at 5:28:13 AM | Imported family colors and shadows
gebber
gebber Avatar
5 Stars: 4 Votes
"colors will not show once the familly is in the project"
When you load a family in the project the familly's materials appear as set in the project.
2 ways to figure this out:
1. In your project
Go to manage -> materials and check the materials metal & maple they are probably not set correctly, choose the material)
2. In the family
go to manage -> materials change the name of the used materials. -> load into project.
Thu, Sep 30, 2010 at 8:18:31 AM | Imported family colors and shadows
samuelab
I figured it out!. It was not the materials.
 Since I am using Revit MEP, the default view template applied to 3d view (or most new views for that matter) only gives color to MEP equipment (ex: lighting fixtures, plumbing, electrical boxes...) .
 By applying thearchitetural presentation view template on the view, the problem is solved! Both for colors and shadows. Thnaks for all the help guys Smile
Family Materials on Imported SKP files: Car colors
Mon, May 9, 2011 at 7:40:07 PM
Getting rid of shadows in Revit rendering?
Sun, Dec 3, 2017 at 2:06:46 AM
Strange shadows on render (imported CAD blocks)
Mon, May 21, 2012 at 8:29:21 AM
Changing colors and materials in an imported model
Fri, Dec 17, 2010 at 4:55:47 PM
autocad layers change color when imported into revit
Sat, Oct 3, 2020 at 12:20:19 PM
14
Page generation time: 3.1250
