22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> IF Parameter
3 Posts No Rating |
So I've got this closet with shelves in them. What I want it to do is: if the height of the closet is lower then the height of the upper shelve, then I want that upper shelve to disappear, to be not visible. I've tried doing this with the IF parameter, but I can't get it to work. Right now this is what i got IF (Height Closet < Height Shelve 3, NOT (Shelve 3), Shelve 3) I'm not a bit new to using parameters and formulas, so I've got no idea if this is even close to correct. I'm using the NOT parameter since this is how I was told to control visibilty. So if anyone is able to help me or point me in the right direction, i'd be very happy.
You should be able to set this by setting the visibility of the shelf to something like: Height Closet > Height Shelve 3 ... but I would have to verify that.
3 Posts No Rating |
Yup that did the trick. Thx a ton :D
Can a Yes/No Parameter control a Length Parameter? |
Thu, Mar 22, 2012 at 12:17:27 AM
Referencing a Shared Parameter in a Family parameter formula. |
Thu, Jan 29, 2015 at 1:26:24 PM
Add angle parameter to generic annotation with offset parameter |
Mon, Mar 2, 2020 at 12:57:06 AM
Add Family name to a shared parameter |
Tue, Jun 23, 2015 at 8:50:48 AM
NOT Parameter Formula Question |
Fri, Apr 10, 2009 at 8:30:17 AM
