18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Ho to send an object to background (line-weight problem)
1 Posts No Rating |
Hi everyone, I have a problem with object line weight in Revit. when you put an object on the wall n plan view it covers a part wall. the thickness of wall outline is thicker than the object (let's say a furniture system). the problem occurs when you try to print out, that area which has been covered by object shows up and it doesn't let the wall border to be appear as same thickness. in Autocad you can send the object to back by draworder command, what should I do in revit? Thanks in advanced
Use the linework tool in the plan view and your tab key to change that common line.
LINE WEIGHT PROBLEM IN PRESPECTIVE |
Tue, Mar 13, 2012 at 3:26:45 PM
Making Line Weight a Parameter? |
Mon, Mar 19, 2007 at 1:59:55 PM
problem printing line weight to pdf |
Tue, Sep 30, 2014 at 3:31:49 PM
Line weight in family doesn't equal line weight in project |
Fri, May 31, 2013 at 2:54:29 PM
Line Weight as Family Parameter |
Fri, Mar 16, 2007 at 4:23:58 PM
