37 Users Online (36 Members):
Forums >> Revit Structure >> Technical Support >> Linework Problems:
1 Posts No Rating |
I am working on enlarged scaled floor plans. When I plot to our plotter, the line weight is huge. Not all the lines in the image... Dimension lines and Column tags and centerlines. The image on my screen of the enlarged plans are thin line weight, and have the thin lines picked from the view panel.
Thin lines is a display only option. It doesn't change how it plots. Thick lines shows you how it will plot. So it sounds like you need to reset your category lineweights for the project or for the view in question.
Edited on: Thu, Sep 23, 2010 at 12:08:52 PM
also remember each scale has it's own set of lineweights applied to it.
Can you save linework? |
Tue, Aug 12, 2008 at 7:37:07 PM
Linework tool issue |
Mon, Sep 26, 2011 at 3:20:44 PM
Improving Linework in Sections & Elevations |
Sun, Mar 30, 2008 at 12:30:48 AM
How to delete linework created by underlay |
Tue, Jan 31, 2012 at 9:45:57 AM
Linework on column woes |
Fri, Apr 29, 2005 at 12:40:35 PM
