50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Decals Rendering as black
Mon, Sep 20, 2010 at 7:45:12 PM | Decals Rendering as black
tomdub90
I'm having an issue where I go to render views and the decal's that I have applied render as black, yet the JPG file information is all there under the Decal type.
 Also when I go to realistic view (using Revit2011) the decal's image appears, so it only appears as black when rendered.
 Can anybody help me out?
 Thanks
Tue, Sep 21, 2010 at 5:22:11 AM | Decals Rendering as black
4 Stars: 201 Votes
Go to Options > Rendering and add a path where you have your decals (jpg files)
Tue, Sep 21, 2010 at 8:47:28 PM | Decals Rendering as black
tomdub90
Hmm. Didn't fix the problem. If it helps, It worked when I first rendered the decal, the JPG was displayed. But then I placed more than one of the decal and added new decals and then they appeared black. So i deleted all the decals and loaded the one decal again and it still renders as black.
 I'm not an expert on rendering, so I'll post all the decal type info to see if there are any conflicting things that could result in it rendering black.
the Bitmap is a jpg so no issues there.
unifiedbitmap_RGBAmount = 1       Reflectivity = 0%                Transparency = 0%           Finish = Matte                    Luminance= not illuminated           Bump Pattern = (BLANK)      Bump Amount = 30%       Cutouts = None
 Cheers for the help.
Wed, Sep 22, 2010 at 4:43:15 AM | Decals Rendering as black
4 Stars: 201 Votes
Maybe this is the problem: www.revitcity.com/forums.php?action=deletepost&thread_post_id=58760&thread_id=16237
Edited on: Thu, Sep 23, 2010 at 4:24:35 AM
Wed, Sep 22, 2010 at 2:45:51 PM | Decals Rendering as black
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Link doesn't work, Ty..........
Wed, Sep 22, 2010 at 2:48:47 PM | Decals Rendering as black
4 Stars: 201 Votes
Yes it work ERl, just click on the link...
Wed, Sep 22, 2010 at 3:17:16 PM | Decals Rendering as black
erland73
erland73 Avatar
4.5 Stars: 85 Votes
"Yes it work ERl, just click on the link..."....yes Ty, I know that... Frowning
Wed, Sep 22, 2010 at 3:27:28 PM | Decals Rendering as black
4 Stars: 201 Votes
YES it work: http://screencast.com/t/MmU2ZmFjMz
Wed, Sep 22, 2010 at 8:37:30 PM | Decals Rendering as black
tomdub90
Yeah... sorry Typhoon. No can see... you could copy and paste the whole thread to this one Winking
 BUT from what I did see from your screen shot, I don't think that that is my issue because it still shows up in realistic mode as the proper JPG in the correct position. So the Decal is definitely placed in the correct position as shown below.
Wed, Sep 22, 2010 at 9:55:44 PM | Decals Rendering as black
erland73
erland73 Avatar
4.5 Stars: 85 Votes
"Yeah... sorry Typhoon. No can see...".....I told you Ty...hehe....tomdub90, can you upload your bitmap?
Wed, Sep 22, 2010 at 11:47:58 PM | Decals Rendering as black
#11
tomdub90
It's not a unique problem to the one pic. Happens with all JPGs. But here. Have some advertising!
Thu, Sep 23, 2010 at 12:02:35 AM | Decals Rendering as black
#12
tomdub90
ooo. dead image. thats suspicious. I think I have it figured out. It's the image's fault. The images are stored on an external company server. but then When I save it to the desktop it still has the same issue. Whereas images processed through photoshop don't have the issue. SO... i opened up the image in Paint and then saved as new.... but still the samething happened.
 Then i try opening it in Photoshop and it tells me the ICC profile is invalid... whatever that is... oh colour space.
 Ok its working. I saved it as a bmp through PS and it now works. WIERD... funky images. But Thats it resolved.
thanks guys!
Thu, Oct 7, 2010 at 10:29:04 AM | Decals Rendering as black
#13
fabiyamanaka
tomdub90 I had the same problem. My jpgs were in CMYK, I tried to save them as RGB and worked.
Fri, Jan 7, 2011 at 10:34:33 AM | Decals Rendering as black
#14
LOSpistos
  1. same problem..pleeease whats the conclusion?
Sat, Jan 8, 2011 at 11:42:50 PM | Decals Rendering as black
#15
asser
Same problem after upgrading to 2011. It worked fine in 2010 but now all images rendering black. I tried resave images with a different ICC profile and in various file formats but with no effect.
BTW same problem in a new file that was not upgraded from 2010 format.
Any tips appreciated!
problem rendering decals
Tue, Aug 3, 2010 at 8:18:16 AM
problem with rendering decals
Mon, May 14, 2007 at 5:44:57 PM
Decals not Rendering in 2010/12
Wed, Jul 20, 2011 at 1:34:53 PM
Rendering Decals
Fri, May 8, 2009 at 11:45:11 AM
applying different type of decals
Wed, Mar 23, 2011 at 5:45:44 PM
Page generation time: 0.4829
