Forums >> Revit Building >> Technical Support >> Phase render materials
Mon, Sep 20, 2010 at 1:14:12 PM | Phase render materials
a4arch
Is it possible to phase materials? As in have an exsisting render material be different from the new construction material on a wall that is not being demolished? For example painted shingles replaced with clapboard siding.
Thu, Sep 23, 2010 at 11:31:46 PM | Phase render materials
eldados
eldados Avatar
4.5 Stars: 8 Votes
you can assign a graphic override phase material but this is changing all elements to use that material,this is handy in situations where you want to show the whole model as one colour (like those white cardboard renders you see around).
to do that, go into your phase settings--> graphic override, on the existing phase the right column is Materials, you can set the material there.
HTH
Integrator
KarelCAD
Render materials lost link
Mon, Nov 30, 2009 at 9:36:59 AM
Render problem in 2009 with existing phase
Thu, Aug 28, 2008 at 2:55:45 PM
Materials not showing in render
Wed, Jul 6, 2011 at 1:14:38 PM
Can't get any materials to render
Tue, Jun 2, 2009 at 9:49:29 AM
Materials for 3D / Render
Fri, Sep 9, 2011 at 8:40:34 AM
Page generation time: 0.7686
