34 Users Online (32 Members):
Forums >> Revit Systems >> Technical Support >> DUCTWORK-CHANGING THE OFFSET STANDARD IN HIDDEN LINE
41 Posts No Rating |
I am currently having trouble publishing sheets of ductwork in hidden line format because the offset for the duct to trim around is cutting out my diffusers. It looks fine when you zoom in in the view and on the sheet, but woce published the trimming takes effect and I almost completely lose my diffusers. Does anyone have any advice for where i might find and edit this setting? If it is even possible.
Don't quite understand the problam can you upload an image and explain?
I CANT UPLOAD AN IMAGE BUT I CAN TRY TO EXPLAIN BETTER. THE DUCTWORK HAS A BUILT IN TRIM SETTING THAT TRIMS EITHER ANOTHER DUCT PASSING UNDERNEATH, OR IN THIS CASE A DIFFUSER. THE DUCTS THAT PASS UNDERNEATH CHANGE TO HIDDEN LINE FORMAT TO SHOW THAT THEY ARE UNDERNEATH, AND TRIM OFF OF THE BELOW A LITTLE ON EITHER SIDE OF THE OVERHEAD DUCT. MY PROBLEM IS WHEN IT TRIES TO SHO THE DIFFUSER UNDER THE DUCT IT TRIMS OFF TOO MUCH SO YOU CANT SEE THE DIFFUSER ANYMORE. IN CAD WE WOULD JUST LOWER THE TRIM OFFSET FROM SAY 3" TO 2" AND I WAS WONDERING IF THERE WAS A WAY TO CHANGE THE SETTING IN REVIT FOR THE OFFSET THAT THE DUCTWORK AUTO TRIMS AT? I HOPE THIS IS MORE CLEAR, IM SORRY IF IT IS NOT.
Printing vector changes solid to hidden line, shaded areas don't show correctly |
Mon, Apr 20, 2015 at 10:56:21 AM
REVIT MEP 2012 Ductwork Connection to Sidewall Diffuser |
Wed, Mar 20, 2013 at 3:31:59 PM
Revit MEP 2010 Ceiling Plans and Ductwork/Air Devices |
Tue, Jan 19, 2010 at 8:56:50 AM
Exporting quality hidden line views |
Fri, Jul 8, 2005 at 4:02:23 AM
Line weights reverting to standard |
Thu, Jan 6, 2011 at 7:10:38 AM
