Forums >> Revit Building >> Technical Support >> Design a apartment, should start from mass study or walls
Mon, Aug 23, 2010 at 3:49:14 AM | Design a apartment, should start from mass study or walls
zazem
Hi,
I am first time design an simple 4 storage apartment, should I start from mass study or placing walls and floors?
thx
Mon, Aug 23, 2010 at 4:17:15 AM | Design a apartment, should start from mass study or walls
4 Stars: 205 Votes
You decide but if it's a "Simple 4 storage apartment" i think i start placing the walls and floors unless i really need a Solar mass study.
Mon, Aug 23, 2010 at 7:34:53 AM | Design a apartment, should start from mass study or walls
zazem
Thx Typhoon
What's benefits of using Mass study?
I saw the offical tutorial from autodesk using mass to form the building,, that's why i am confusing which one to go for.
Mon, Aug 23, 2010 at 12:57:46 PM | Design a apartment, should start from mass study or walls
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Hi,
We have a few designers here using Revit to start out a project and to be honest with you, we almost never use massing. Most of the time, they have an idea that they want and just start, as Ty says, placing walls and what not. Plus, a lot of our designs begin at design charrettes and we find they don't want to see masses, but actual building components.
We use massing to figure out some more of the complex design issue if need be.
I imagine as the industry starts to get into the sustainable side of design, more of use will use massing for solar analysis and things of that nature.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Mon, Aug 23, 2010 at 4:44:42 PM | Design a apartment, should start from mass study or walls
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I'll chime in with both Ty and Brett to agree, unless you want to design something extremely unusual, stick with the basics they are hard enough to start with.
Change mass colour for massing study
Mon, Nov 24, 2008 at 4:52:34 AM
What projects to start designing in revit help needed please
Tue, Sep 20, 2022 at 2:52:27 AM
Wall schedule by apartment unit
Mon, Sep 29, 2008 at 7:14:49 AM
walls disassociated with mass - can't update walls
Fri, Nov 2, 2012 at 10:51:18 AM
How do you make a parametric mass with dimensions and void visibility and volume
Mon, Nov 23, 2015 at 10:03:27 PM
Page generation time: 0.5628
