Forums >> Revit Structure >> Technical Support >> Revit crashes when I add a wall sweep
Sun, Aug 22, 2010 at 10:22:29 PM | Revit crashes when I add a wall sweep
jrogers3
I am fairly new to Revit and need to know why I can't add a vinyl base to a wall as a wall sweep. Every time I do the program crashes.
Mon, Aug 23, 2010 at 4:13:26 AM | Revit crashes when I add a wall sweep
4 Stars: 205 Votes
Not enought information to answer this question.
Be more specific, Revit version, do you have the Updates installed, specs. of the machine, OS system - 32 64 bits and so one, some screenshots will help too.
Mon, Aug 23, 2010 at 7:17:20 AM | Revit crashes when I add a wall sweep
jrogers3
Thanks for responding. Revit 2011, OS is XP, I installed the 32 bit version. What kind of screen shots would be helpful?
Mon, Aug 23, 2010 at 7:20:09 AM | Revit crashes when I add a wall sweep
Ty also asked if you had installed the 2011 updates?
Revit 2012 crashes applying wall sweeps
Tue, Feb 26, 2013 at 9:43:55 PM
How to Load a Wall sweep type
Mon, Jun 9, 2008 at 12:42:29 PM
Wall Sweep/Siding
Sun, Feb 17, 2008 at 12:11:00 PM
Custom profile for wall sweep
Mon, Jul 1, 2013 at 2:06:01 PM
11
Sloped sweep in Revit 2010, can it be done?
Sat, Jan 12, 2013 at 5:22:13 AM
Page generation time: 2.2934
