Forums >> Revit Building >> Technical Support >> table creation
Sat, Aug 21, 2010 at 11:11:15 AM | table creation
hhwse
I am attempting to create tables for my special inspection requirements.  I have had some success by using schedule keys.  I have attached a pdf of what I am trying to do.  I can get the headings correct by using the grouping functions.  What I have not figured out is how to group the rows.  The “code or standard reference” and “remarks” columns should cover multiple row line items.   Is there any way to do this in Revit?
Sun, Aug 22, 2010 at 10:33:36 AM | table creation
As with any program, you have to adapth your expectations to the limits of the program.  Revit is not excel and can not do what excel does.  And it isn't CAD.  In CAD - most or all of this would be text and you could do that here.  But Revit does a great job of reporting content, you just have to adapt your wants to how you can display that information.  In this case:
  1. Your headers look like they will work except you can not have two rows in the title.  If you have to have tis, you could add some of it in "paper space"
  2. The "code or standard reference" column can not be combined across record rows so this will be repeated for each row.
  3. The row information will not be centered vertically in the cell as you show it in the first two and "periodic" columns.
  4. Your major -sorts, such as "Smoke Control Systesms" should be a parameter that is in a seperate column that is turned off but used in your sort heading.  It would be your first column and will show on the left instead of centered as you show it.
Sun, Aug 22, 2010 at 5:46:12 PM | table creation
hhwse
Thanks for the reply.Here is what I have come up with so far.  The main problem I am having is how to make the “remarks” column.  There are comments that apply to a group of inspections and have too much text to include on each line item.  The only way I have thought of to do this is by using foot notes, but that is messy.
Mon, Aug 23, 2010 at 7:16:39 AM | table creation
You could use a foot-note:  See Note A below.
And obviously - that would be text - not in the schedule.
Edited on: Mon, Aug 23, 2010 at 7:17:18 AM
Family Creation Look-up table interactivity
Thu, Jul 24, 2014 at 7:38:37 AM
foldable table???
Mon, Nov 29, 2010 at 7:25:54 AM
an automated retractable screen table
Mon, Jun 18, 2018 at 10:44:36 AM
table family legs misaligned when imported into project
Tue, Sep 20, 2011 at 5:00:10 PM
creating excel-like table in revit---Is it possible?
Wed, Mar 16, 2005 at 12:19:53 AM
Page generation time: 1.3097
