Forums >> Revit Structure >> Technical Support >> Suspended Slab problem
Wed, Aug 18, 2010 at 8:36:51 PM | Suspended Slab problem
andrew076
Hi,
I'm drawing a suspended slab of varying thickness with band beams.  I've used 'concrete beams (girders)' for the band beams and the slab changes thickness on the centreline of the beams.  The problem is in plan a line shows up where the slab changes thickness even though I've joined the geometry in section (and it looks ok in section).
 Can anyone suggest either a better way of varying the thickness of the slab or a way of hiding the junction of the two different slab thicknesses ?
 Thanks
Andrew
Thu, Aug 19, 2010 at 3:15:32 AM | Suspended Slab problem
4 Stars: 205 Votes
I don't have Revit here right now but in that plan view in VG expand "Slab" then you have a parameter (i don't remember the name) where you can turn off (invisible) those lines automatically instead using the linework tool..
How to encase/return a suspended ceiling
Mon, Nov 16, 2009 at 4:33:54 AM
Suspended Lighting
Fri, Jul 18, 2008 at 3:47:13 PM
How to model suspended ceiling in revit 2017
Sat, Nov 23, 2019 at 7:58:34 AM
Suspended Ceiling Light Issue
Wed, Sep 23, 2020 at 4:57:15 PM
Mirror problem about slab edge
Fri, May 20, 2011 at 7:02:38 AM
Page generation time: 0.7427
