933 Users Online (40 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Building >> Technical Support >> Understanding the coordinate systems
Tue, Aug 17, 2010 at 3:23:41 AM | Understanding the coordinate systems
archie456
3 Stars: 1 Votes
Hi,
I’m trying to get my head around the co-ordinate system in Revit.
I’ve written out below my understanding of it, from reading the help and various tutorials.
I would appreciate someone say confirming if I’ve missed anything.
Cheers.
·         There are two co-ordinate systems in Revit one relates to the Project Base point, the other relates to the Survey Point.
·         Project Co-ordinates and Project North are the internal Revit co-ordinates.
·         A Named Position – This is used where there are several instances of the same building – each position represents one instance.
·         A survey point is a point which references a known point in the real world – i.e. a survey base station
·         When the survey point is moved and the paper clip is off, the coordinates of the survey point change in relation to the Project Base Point (i.e. the Project Base Point doesn’t move).
·         When the survey point is moved and the paper clip is on (not crossed through) the survey points co-ordinates don’t change and the Project Base Point moves.
·         When you move the Project Base point with the paper clip on (not crossed through) the entire co-ordinate system moves – effectively you pan the drawing – but the Survey point doesn’t change its co-ordinates.
·         When you move the Project Base point with the paperclip off it moves the icon, but doesn’t change the Project co-ordinates – I don’t see the point of this other than to move the icon.
Vertical Hatch Pattern
Wed, Feb 17, 2016 at 8:43:02 AM
Dealing with plumbing systems
Fri, Aug 31, 2012 at 5:27:33 PM
Placing Lighting Fixtures in Revit Systems
Wed, Nov 15, 2006 at 7:59:29 AM
Move entire model to a different level!???
Sun, Jan 31, 2010 at 12:39:51 PM
Will the reset the Survey point affect consultant links?
Fri, Oct 22, 2010 at 10:26:13 AM
Page generation time: 0.0573
